Hi.
First, let med apologize for not writing in German. I'm from Denmark, and read a lot of the T18 info in this forum, but my written German is 'Sehr schlecht'...
I'm playing arround with the 18's p.mix, but can't seem to work this one out.
What I want is: overrule the throttle channel by a switch, and set the positions.
Eg:
Switch C up: Mix inactive, throttle follows the throttle curve
Switch C mid: Throttle output +40% no matter what the throttle curve says
Switch C down: Throttle output +100% no matter what the throttle curve says
No matter what settings I use in the P. Mix or Offset mixing, the settings/curve is added to the current throttle curve output, but I want to overrule it.
Can this be done ?
Best Regards
Kim
Eg:
Can this be done ?
Best Regards
Kim
