Ich kann nur ein bisschen Deutsh sprache lesen und shreiben aber ich denke dass dieses forum ist ein gut platz zu fragen. Bitte enschuldigung aber ich muss shreiben auf inglisch (es tut mir leid aber ich denke es ist better für ihr auch )
I noticed a strange bug with my brand nex FX-30. The range check function doesn't work if I just change the model, it only works after powering on the transmitter.
This way works well:
-power on the transmitter
-answer NO, do not start transmitting
-select range check function is the first menu
If you change the model and answer NO to not begin the Tx it should work as well but it doesn't. In this case I get a screen with an endless progressbar and I am forced to power off and power on the transmitter again to escape.
In another words: only the model selected when the transmitter is powered on enables the use of the range check function. If you change model, it doesn't work. (you must power off/on again and the new model will be selected enabling range check next time).
Note that teh problem is only with range check, the transmission at full power starts well everytime.
Do you have the same problem?
Thank you and sorry again for not writing in the forum official language.
Best regards,
Thomas
Setup:
-FX-30 software 1.4 / TM14 / rx 6014
-english menus
-no sd card in the transmitetr
-tried 2.4GHz general and 2.4GHz France, the problem is the same
Best regards,
Thomas
Setup:
-english menus
